nepi-ng - C - managing files
Scenario
In this series, we will see how to transfer files between hosts, using
the Push
and Pull
commands in a SshNode
The version in C3 will perform the following:
- generate a random file locally, and transfer it using SFTP onto fit01
- transfer it from fit01 to fit02 over the data network using netcat
- finally retrieve it locally from fit02 using SFTP again, and compare the result to make sure the file is intact.
The progression from C1 to C3 matches these bullets : C1 just performs the first bullet, and C2 performs the first two bullets.
The last scenario, labelled C3bis, is a variant around C2. It is not crucial to see it when first reading this tutorial. In this scenario, we perform the exact same scenario as in C2, but we see a recipe to start and stop a process in sync with the jobs in a scheduler.
New features
We will meet the LocalNode
object that will let use run local
commands just like on remote nodes.
We will also take this chance to see that a SshJob
object can be
defined with several commands, which can be helpful to avoid the
need to create long strings of jobs.
We also introduce the Sequence
object, that is a convenience tool
for creating, well obviously, sequences of jobs, without the hassle of
managing the required
relationship for each job.
Finally throughtout this series, we will also illustrate another possible way to manage the components of the scheduler: instead of creating the scheduler at the end with all the jobs, we create the scheduler at the very beginning and create the jobs right into the scheduler. Of course the result is exactly the same, it's just another programming style that is probably worth considering.
Let us start with copying files over to the
node with the Push
command object.
Objective
We start over from scratch here, and to begin with, we want to
- locally generate a random file,
- and push it over to node fit01
This is what the code below carries out; the things to outline in this code are
we see for the first time the
LocalNode
object, that can be used almost exactly as aSshNode
object - except that it is of course simpler to build;once the local file is created, we use a
Push
instance instead of theRun
and its variants that we have seen so far, to actually copy local files on the remote node;also note that inside a single
SshJob
instance, it is possible to provide an (ordered) list of commands to run on that node, mixing commands and file transfers as needed; this is how we can both push theRANDOM
file over to node1, and display its size and SHA1 sum, using a single instance ofSshJob
The code
#!/usr/bin/env python3 import sys, os import asyncio from argparse import ArgumentParser from asynciojobs import Scheduler from apssh import SshNode, SshJob, LocalNode from apssh import Run, RunString, Push ########## gateway_hostname = 'faraday.inria.fr' gateway_username = 'inria_r2lab.tutorial' verbose_ssh = False random_size = 2**10 # this time we want to be able to specify username and verbose_ssh parser = ArgumentParser() parser.add_argument("-s", "--slice", default=gateway_username, help="specify an alternate slicename, default={}" .format(gateway_username)) parser.add_argument("-v", "--verbose-ssh", default=False, action='store_true', help="run ssh in verbose mode") args = parser.parse_args() # override globals from the command line gateway_username = args.slice verbose_ssh = args.verbose_ssh ########## the nodes involved faraday = SshNode(hostname = gateway_hostname, username = gateway_username, verbose = verbose_ssh) # saying gateway = faraday means to tunnel ssh through the gateway node1 = SshNode(gateway = faraday, hostname = "fit01", username = "root", verbose = verbose_ssh) ########## create the scheduler instance upfront scheduler = Scheduler() check_lease = SshJob( node = faraday, critical = True, command = Run("rhubarbe leases --check"), scheduler = scheduler, ) ########## 1 step, generate a random data file of 1 M bytes create_random_job = SshJob( # Using LocalNode() means this will run on our laptop node = LocalNode(), commands = [ Run("head", "-c", random_size, "<", "/dev/random", ">", "RANDOM"), Run("ls", "-l", "RANDOM"), Run("shasum", "RANDOM"), ], required = check_lease, scheduler = scheduler, ) ########## 2nd step : push this over to node1 push_job = SshJob( node = node1, commands = [ Push( localpaths = [ "RANDOM" ], remotepath = "."), Run("ls -l RANDOM"), Run("sha1sum RANDOM"), ], required = create_random_job, scheduler = scheduler, ) ########## # run the scheduler ok = scheduler.orchestrate() # give details if it failed ok or scheduler.debrief() # producing a dot file for illustration scheduler.export_as_dotfile("C1.dot") # return something useful to your OS exit(0 if ok else 1)
Sample output
faraday.inria.fr:Checking current reservation for inria_r2lab.tutorial : OK
LOCALNODE:-rw-r--r-- 1 tparment staff 1024 May 12 11:01 RANDOM
LOCALNODE:255e13ecab298831d82e4edba1bc654f4d634b4d RANDOM
fit01:-rw-r--r-- 1 root root 1024 May 12 11:01 RANDOM
fit01:255e13ecab298831d82e4edba1bc654f4d634b4d RANDOM
Next
In the next section we will extend this scenario, and push the RANDOM file on another node using the wired network.
Objective
We extend the C1 scenario and push the RANDOM file from fit01 to fit02 over the wired network.
So we reuse the turn-on-data
commands, that we had seen in the B
series already, to enable the data
interface.
File transfer per se
In order to transfer the file from fit01 to fit02: of course we could
have used simple tools like plain scp
. Our goal however here is more
to show how to orchestrate such transfers in an environment closer to
typical experimental conditions.
So in this first variant, we will use netcat
; we start with running
a server instance of netcat on the receiving end (in our case
fit02
), then run a client netcat on the sender side (here fit01
In terms of synchronization, note how we
start the server side in background (with a
); the corresponding job hence returns immediately;which lets us start the client side almost immediately afterwards (well, we add a 1s delay to stay on the safe side)
and luckily enough, the server-side server will terminate as soon as the client side netcat is done; so we essentially do not need to worry about stopping the server, it stops itself at the exact right time
so once the sender client is done, we can proceed and display the received file on fit02.
The purpose of the C3bis script is to show how one can use shell tricks to deal with less fortunate situations, where typically the server side runs forever, but you need to stop it once some other job is done.
The Sequence
object
Note the use of the Sequence
object in variable transfer_job
, that
almost entirely relieves us of managing the required
relationships.
All the jobs inserted in the Sequence
have their required
relationship set to the previous job in the list, by setting
required
on the Sequence
object we actually deal with the
required
jobs for the first job in the sequence.
Finally, by setting scheduler
on this transfer_job
object, we
automatically attach all the jobs in the sequence to the global
scheduler.
The code
#!/usr/bin/env python3 import sys, os import asyncio from argparse import ArgumentParser from asynciojobs import Scheduler, Sequence from apssh import SshNode, SshJob, LocalNode from apssh import Run, RunString, Push ########## gateway_hostname = 'faraday.inria.fr' gateway_username = 'inria_r2lab.tutorial' verbose_ssh = False random_size = 2**10 netcat_port = 10000 # this time we want to be able to specify username and verbose_ssh parser = ArgumentParser() parser.add_argument("-s", "--slice", default=gateway_username, help="specify an alternate slicename, default={}" .format(gateway_username)) parser.add_argument("-v", "--verbose-ssh", default=False, action='store_true', help="run ssh in verbose mode") args = parser.parse_args() gateway_username = args.slice verbose_ssh = args.verbose_ssh ########## the nodes involved faraday = SshNode(hostname = gateway_hostname, username = gateway_username, verbose = verbose_ssh) # saying gateway = faraday means to tunnel ssh through the gateway node1 = SshNode(gateway = faraday, hostname = "fit01", username = "root", verbose = verbose_ssh) node2 = SshNode(gateway = faraday, hostname = "fit02", username = "root", verbose = verbose_ssh) # for convenience, a collection of the nodes # that we need to initialize nodes = (node1, node2) ########## create the scheduler instance upfront scheduler = Scheduler() check_lease = SshJob( node = faraday, critical = True, command = Run("rhubarbe leases --check"), scheduler = scheduler, ) ########## 1 step, generate a random data file of 1 M bytes create_random_job = SshJob( node = LocalNode(), commands = [ Run("head", "-c", random_size, "<", "/dev/random", ">", "RANDOM"), Run("ls", "-l", "RANDOM"), Run("shasum", "RANDOM"), ], required = check_lease, scheduler = scheduler, ) ########## 2nd step : push this over to node1 push_job = SshJob( node = node1, commands = [ Push( localpaths = [ "RANDOM" ], remotepath = "."), Run("ls -l RANDOM"), Run("sha1sum RANDOM"), ], required = create_random_job, scheduler = scheduler, ) ########## step 3 : turn on data interfaces # a convenient way to create many jobs in a single pass is # to build a list of jobs using a python comprehension turn_on_datas = [ SshJob( node = node, command = Run("turn-on-data"), required = push_job, scheduler = scheduler, ) for node in nodes ] ########## next : run a sender on node1 and a receiver on node 2 # in order to transfer RANDOM over a netcat session on the data network # a Sequence object is a container for jobs, they will have their # 'required' relationship organized along the sequence order transfer_job = Sequence( # start the receiver - this of course returns immediately SshJob( node = node2, commands = [ Run("netcat", "-l", "data02", netcat_port, ">", "RANDOM", "&"), ], ), # start the sender SshJob( node = node1, # ignore netcat result critical = False, commands = [ # let the server warm up just in case Run("sleep 1"), Run("netcat", "data02", netcat_port, "<", "RANDOM"), Run("echo SENDER DONE"), ], ), # check contents on the receiving end SshJob( node=node2, commands = [ Run("ls -l RANDOM"), Run("sha1sum RANDOM"), ], ), ### these two apply to the Sequence # required applies to the first job in the sequence required = turn_on_datas, # scheduler applies to all jobs in the sequence scheduler = scheduler, ) ########## # run the scheduler ok = scheduler.orchestrate() # give details if it failed ok or scheduler.debrief() # producing a dot file for illustration scheduler.export_as_dotfile("C2.dot") # return something useful to your OS exit(0 if ok else 1)
Sample output
LOCALNODE:ffb614df2dc006d4bd568bc6e0efa8454e72a04a RANDOM
fit01:-rw-r--r-- 1 root root 1024 May 12 11:02 RANDOM
fit01:ffb614df2dc006d4bd568bc6e0efa8454e72a04a RANDOM
fit01:data
fit02:data
fit01:SENDER DONE
fit02:-rw-r--r-- 1 root root 1024 May 12 11:02 RANDOM
fit02:ffb614df2dc006d4bd568bc6e0efa8454e72a04a RANDOM
Next
In the next section we will see how to retrieve back that same file in order to close the loop.
Objective
In this scenario, we extend again C2 to close the loop, and retrieve our random file back on the local laptop.
The Pull
object
The only new thing here is the use of a Pull
object, which like for
the Push
object, can be used in a list of commands to run on a given
node as part of a SshJob
The code
#!/usr/bin/env python3 import sys, os import asyncio from argparse import ArgumentParser from asynciojobs import Scheduler, Sequence from apssh import SshNode, SshJob, LocalNode from apssh import Run, RunString, Push, Pull ########## gateway_hostname = 'faraday.inria.fr' gateway_username = 'inria_r2lab.tutorial' verbose_ssh = False random_size = 2**10 netcat_port = 10000 # this time we want to be able to specify username and verbose_ssh parser = ArgumentParser() parser.add_argument("-s", "--slice", default=gateway_username, help="specify an alternate slicename, default={}" .format(gateway_username)) parser.add_argument("-v", "--verbose-ssh", default=False, action='store_true', help="run ssh in verbose mode") args = parser.parse_args() gateway_username = args.slice verbose_ssh = args.verbose_ssh ########## the nodes involved faraday = SshNode(hostname = gateway_hostname, username = gateway_username, verbose = verbose_ssh) # saying gateway = faraday means to tunnel ssh through the gateway node1 = SshNode(gateway = faraday, hostname = "fit01", username = "root", verbose = verbose_ssh) node2 = SshNode(gateway = faraday, hostname = "fit02", username = "root", verbose = verbose_ssh) nodes = (node1, node2) ########## create the scheduler instance upfront scheduler = Scheduler() check_lease = SshJob( node = faraday, critical = True, command = Run("rhubarbe leases --check"), scheduler = scheduler, ) ########## 1 step, generate a random data file of 1 M bytes create_random_job = SshJob( node = LocalNode(), commands = [ Run("head", "-c", random_size, "<", "/dev/random", ">", "RANDOM"), Run("ls", "-l", "RANDOM"), Run("shasum", "RANDOM"), ], required = check_lease, scheduler = scheduler, ) ########## 2nd step : push this over to node1 push_job = SshJob( node = node1, commands = [ Push( localpaths = [ "RANDOM" ], remotepath = "."), Run("ls -l RANDOM"), Run("sha1sum RANDOM"), ], required = create_random_job, scheduler = scheduler, ) ########## step 3 : turn on data interfaces # a convenient way to create many jobs in a single pass is # to build a list of jobs using a python comprehension turn_on_datas = [ SshJob( node = node, command = Run("turn-on-data"), required = push_job, scheduler = scheduler, ) for node in nodes ] ########## next : run a sender on node1 and a receiver on node 2 # in order to transfer RANDOM over a netcat session on the data network # a Sequence object is a container for jobs, they will have their # 'required' relationship organized along the sequence order transfer_job = Sequence( # start the receiver - this of course returns immediately SshJob( node = node2, commands = [ Run("netcat", "-l", "data02", netcat_port, ">", "RANDOM", "&"), ], ), # start the sender SshJob( node = node1, # ignore netcat result critical = False, commands = [ # let the server warm up just in case Run("sleep 1"), Run("netcat", "data02", netcat_port, "<", "RANDOM"), Run("echo SENDER DONE"), ], ), # check contents on the receiving end SshJob( node=node2, commands = [ Run("ls -l RANDOM"), Run("sha1sum RANDOM"), ], ), ### these two apply to the Sequence # required applies to the first job in the sequence required = turn_on_datas, # scheduler applies to all jobs in the sequence scheduler = scheduler, ) ########## finally : let's complete the loop and ########## retrieve RANDOM from node2 back on local laptop Sequence( SshJob( node = node2, commands = [ Run("echo the Pull command runs on $(hostname)"), Pull(remotepaths = "RANDOM", localpath = "RANDOM.loopback"), ]), # make sure the file we receive at the end of the loop # is identical to the original SshJob( node = LocalNode(), commands = [ Run("ls -l RANDOM.loopback", verbose=True), # this is a python trick to concatenate 2 strings Run("diff RANDOM RANDOM.loopback " "&& echo RANDOM.loopback identical to RANDOM"), ]), scheduler = scheduler, required = transfer_job ) ########## # run the scheduler ok = scheduler.orchestrate() # give details if it failed ok or scheduler.debrief() # producing a dot file for illustration scheduler.export_as_dotfile("C3.dot") # return something useful to your OS exit(0 if ok else 1)
Sample output
LOCALNODE:Run: -> ls -l RANDOM.loopback
LOCALNODE:Run: 0 <- ls -l RANDOM.loopback
LOCALNODE:-rw-r--r-- 1 tparment staff 1024 May 12 11:02 RANDOM
LOCALNODE:00b15964267b11eb8df3e3bd3addb50512b9e81d RANDOM
fit01:00b15964267b11eb8df3e3bd3addb50512b9e81d RANDOM
fit01:data
fit02:data
fit01:SENDER DONE
fit02:00b15964267b11eb8df3e3bd3addb50512b9e81d RANDOM
fit02:the Pull command runs on fit02
LOCALNODE:-rw-r--r-- 1 tparment staff 1024 May 12 11:02 RANDOM.loopback
LOCALNODE:RANDOM.loopback identical to RANDOM
Next
If this is your first reading, we suggest you skip C3bis and go directly to WRAPUP for a conclusion on this series.
Objective
In this particular scenario, we restart from C2.
Remember C2 is about transferring a file from node 1 to node 2 over
the data network, thanks to netcat
. As we had seen at the time, it
is rather fortunate that netcat
in server mode returns as soon as
its (single) client terminates.
There are a lot of cases though, where things are not that simple, and where there is a need to manually terminate / cleanup dangling processes that are no longer useful.
Sometimes, it is only a matter of starting and stopping packaged
services like apache or similar, and in this case all we need to do is
to call things like e.g. systemctl start apache2
and systemctl stop
apache2
In the code below, we will see a technique that can be used to start
and stop, and even monitor, a custom process. This is in
receiver_manager_script
, a small shell script that knows how to
start, stop, and even monitor, a single-process service.
The code
You can still see the difference with C2-files.py
, but let us start with the plain code for C3bis-files.py
#!/usr/bin/env python3 import sys, os import asyncio from argparse import ArgumentParser from asynciojobs import Scheduler, Sequence from apssh import SshNode, SshJob, LocalNode from apssh import Run, RunString, Push ########## gateway_hostname = 'faraday.inria.fr' gateway_username = 'inria_r2lab.tutorial' verbose_ssh = False random_size = 2**10 netcat_port = 10000 # this time we want to be able to specify username and verbose_ssh parser = ArgumentParser() parser.add_argument("-s", "--slice", default=gateway_username, help="specify an alternate slicename, default={}" .format(gateway_username)) parser.add_argument("-v", "--verbose-ssh", default=False, action='store_true', help="run ssh in verbose mode") args = parser.parse_args() gateway_username = args.slice verbose_ssh = args.verbose_ssh ########## the nodes involved faraday = SshNode(hostname = gateway_hostname, username = gateway_username, verbose = verbose_ssh) # saying gateway = faraday means to tunnel ssh through the gateway node1 = SshNode(gateway = faraday, hostname = "fit01", username = "root", verbose = verbose_ssh) node2 = SshNode(gateway = faraday, hostname = "fit02", username = "root", verbose = verbose_ssh) nodes = (node1, node2) ########## create the scheduler instance upfront scheduler = Scheduler() check_lease = SshJob( node = faraday, critical = True, command = Run("rhubarbe leases --check"), scheduler = scheduler, ) #################### utility script to manage a receiver # in order to transfer RANDOM over a netcat session on the data network # receiver_manager_script = """#!/bin/bash source /etc/profile.d/nodes.sh function start() { port=$1; shift outfile=$1; shift # r2lab-id returns a 2-digit string with the node number ipaddr="data"$(r2lab-id) echo "STARTING CAPTURE into $outfile" # start netcat in listen mode netcat -l $ipaddr $port > $outfile & # bash's special $! returns pid of the last job sent in background # preserve this pid in local file echo $! > netcat.pid echo netcat server running on $ipaddr:$port in pid $! } function stop() { echo "STARTING CAPTURE into $outfile" pid=$(cat netcat.pid) # not necessary as netcat dies on its own when clent terminates echo Would kill process $pid rm netcat.pid } function monitor () { while true; do pid=$(pgrep netcat) [ -n "$pid" ] && ps $pid || echo no netcat process # thanks to Ubuntu the shell's sleep can do fractions of seconds sleep .2 done } # usual generic laucher "$@" """ ########## 1 step, generate a random data file of 1 M bytes create_random_job = SshJob( node = LocalNode(), commands = [ Run("head", "-c", random_size, "<", "/dev/random", ">", "RANDOM"), Run("ls", "-l", "RANDOM"), Run("shasum", "RANDOM"), ], required = check_lease, scheduler = scheduler, ) ########## 2nd step : push this over to node1 push_job = SshJob( node = node1, commands = [ Push( localpaths = [ "RANDOM" ], remotepath = "."), Run("ls -l RANDOM"), Run("sha1sum RANDOM"), ], required = create_random_job, scheduler = scheduler, ) ########## step 3 : turn on data interfaces # a convenient way to create many jobs in a single pass is # to build a list of jobs using a python comprehension turn_on_datas = [ SshJob( node = node, command = Run("turn-on-data"), required = push_job, scheduler = scheduler, ) for node in nodes ] ########## next : run a sender on node1 and a receiver on node 2 # start the receiver - this of course returns immediately SshJob( node = node2, commands = [ RunString(receiver_manager_script, "start", netcat_port, "RANDOM", remote_name = "receiver-manager"), ], required = turn_on_datas, scheduler = scheduler, ) transfer_job = Sequence( # start the sender SshJob( node = node1, # ignore netcat result critical = False, commands = [ # let the server warm up just in case Run("sleep 1"), Run("netcat", "data02", netcat_port, "<", "RANDOM"), Run("echo SENDER DONE"), ]), # kill the receiver, and # check contents on the receiving end SshJob( node=node2, # set a label for the various representations # including the graphical one obtained with export_as_dotfile label = "stop receiver", commands = [ RunString(receiver_manager_script, "stop", remote_name="receiver-manager"), Run("ls -l RANDOM"), Run("sha1sum RANDOM"), ]), required = turn_on_datas, scheduler = scheduler, ) SshJob( node = node2, # this job won't finish on its own forever = True, # see above label = "infinite monitor", commands = [ RunString(receiver_manager_script, "monitor", remote_name="receiver-manager"), ], scheduler = scheduler, ) ########## # run the scheduler ok = scheduler.orchestrate() # give details if it failed ok or scheduler.debrief() # producing a dot file for illustration scheduler.export_as_dotfile("C3bis.dot") # return something useful to your OS exit(0 if ok else 1)
Sample output
fit02:Using id=02 and fitid=fit02 - from hostname
LOCALNODE:d6eb748eb3230ff1e2ecf241f3fcf1be513c80b4 RANDOM
fit02:no netcat process
fit01:d6eb748eb3230ff1e2ecf241f3fcf1be513c80b4 RANDOM
fit01:data
fit02:data
fit02:STARTING CAPTURE into RANDOM
fit02:netcat server running on data02:10000 in pid 12675
fit02: PID TTY STAT TIME COMMAND
fit02:12675 ? S 0:00 netcat -l data02 10000
fit01:SENDER DONE
fit02:Would kill process 12675
fit02:d6eb748eb3230ff1e2ecf241f3fcf1be513c80b4 RANDOM
Next
We can now conclude this section
In this C series , we have seen:
how to use the
Push
andPull
commands to copy files back and forth on and from nodes;how to use the
LocalNode
to augment our scripts with commands run locally;how a single
SshJob
can trigger several commands, mixingRun
,RunString
,Push
andPull
types of commands;how to implement (in C3bis) a rustic service management feature, for housekeeping purposes;
and finally, still in C3bis, how to produce a graphical view of a
Scheduler
for documentation and/or troubleshooting.
In the next tutorial we will see how to simply provide a command-line option for loading images on nodes.
